Comparing local and Meteonorm wdr data
james bertram
Post by james bertram »
Good morning (again) - if I have local wind velocity, direction and rainfall, can I total "Rain load = Rain*(R1 + R2*Wind velocity)" in each degree of orientation to create a comparative wind driven rain distribution rose?
If so, is the formula "Rain load = Rain*(R1 + (R2*Wind velocity)) or Rain*((R1 + R2)*Wind velocity)?
Thank you
Re: Comparing local and Meteonorm wdr data
Hi James,
nearly you can total it. You have to include an cosinus as the rain will also hit the surface, if the surface is turned a little bit to the rain direction:
Rain load = sum(Rain * (R1 + (R2 * windspeed)) * cos (winddir - orientationsurface)) for positive values.
In Wufi R1 is set to zero and R2 is set to 0,2 m/s.
Chrisitan
james bertram
G'day Christian - struggling a bit here...(should have done algebra instead of home economics) :wink:
Would you check the following:
"Rain load" = the sum of hourly outcomes for each of the 8 default wall orientations (N=0 deg, NE=45 deg etc)
"Rain" = measured hourly rainfall (mm)
"R1" = 0
"R2" = 0.2
"windspeed" = measured hourly data (m/s)
"cos" = cosine (Excel formula)
"winddir" = direction wind is coming from (270 deg = from the west)
"orientationsurface" = perpendicular or othogonal to the wall (does this mean a wall running east-west is north facing = 0 degs or relative to the wind direction 180 degs?)
"for positive values" = not sure?
When I use the above for each line of hourly data (wind speed, wind direction, rain) my outcomes don't seem to transition from perpendicular wall=higher rain load to oblique wall=small rain load, and the relationship between wind direction and wall is sometime back to front.
I appreciate your support, James
Hello James,
"R1" = 0
"R2" = 0.2
Yes, thats right
yes, but Excel uses radians not degree, so you have to do it this way:
Code: Select all
=cos(radians(value)) or =cos(PI()/180*value)
Then you´ll get positive values for 0-90 and 270 to 360 degree.
Its the direction the surface is facing, so north = 0, west = 270.
See above @cos, you have to sum up the positive values for the wanted direction.
Try if you get that to work, if not I can send you an example xls-file.
Greetings,
james bertram
Thank you Professor :D
I will give it a go first, always learn more that way...and get back to you doesn't seem to work.
Enjoy your weekend..I get to start mine first!
James
