I am working on WUFI Graph 2.5.0. and I can´t visualize user defined series in saved files. I can create and save them but, when I reopen the graphic project, nothing of them are on graphs. I can visualize water content, temperature and relative humidity series but graphs with user defined series are empty.
I have reinstalled it but the problem continues (Vista 32 bits).
Thanks,
Sebastian Boegl
Re: I can´t visualize user defined series in saved files
could you please pm or mail the generated log file to me.
If possible also attach the saved file.
Sebastian
Code: Select all
%APPDATA%\WUFI\WUFIGraph\log.txtIf possible also attach the saved file.
Sebastian
Can't save as/ cut and paste file to a new location
I wonder why I had a similar issue, but not graphys. Seems I can't rename a WUIFI file or cut and paste to a new location, otherwise, when I reopen it is an empty file. I have tried to reboot the PC or reinstall it, still doesn't work. When saved it constantly shows Erro's writing too. Would you advice why this happens, it used to work. Thank yo in advance.
Is this related to WUFI 2D or Pro?
For WUFI Pro this is only working if you have opened up the result file directly from Graph, not if you send the data out from WUFI Pro to Graph.
