Wufi Plus Plugin into Sketchup not working
jwa1
Post by jwa1 »
I installed a wufi plus version 2.5.3 and sketchup version 8. I followed every single step in the web (http://www.wufi-wiki.com/mediawiki/inde ... :Sketch-Up) but the plugin installation failed. The message that always pop up is " plugin could not be installed". Is there any other way to install the plugin or any solution regarding my problem is a great help for me.
Kv.
Jose
Re: Wufi Plus Plugin into Sketchup not working
Post by mpazold »
Hi Jose,
in WUFI Plus Version 2.5.3.0 two essential files are not installed properly, to activate the sketchup plugin.
I've send you those two files per e-mail, please copy them into your wufiplus folder (beside the wufiplus.exe) and try to install the plugin following the steps again. There is no other way to install the plugin at the moment.
Matthias
jwa1
Post by jwa1 »
Hi Matthias,
I copied the two other files (DraftManualWUFIPlus.pdf and WUFI-DB.exe) from the Wufi_plus_2_5_3 that you sent me to the location folder where I installed the Wufi Plus. I follow installation as per instruction but unfortunately problem still the same.. I even try to re-installed Wufi Plus and Sketchup 8 and deactivate the antivirus, but plugin installation still failed. I really don't know how to figure this out. By the way I'm using 32 bits windows vista. Hope there is a solution regarding my concern.
Kv
Jose
Post by mpazold »
I think, finally it works by copy the two files: SKP_WUFIplus_PlugIn.rb and SKPwufi.exe in the next Release this problem will be fixed.
best regards
matthias
