Faced Batt fiber glass insulation
How does you account for the kraft paper on faced fiber glass insulation?
Re: Faced Batt fiber glass insulation
You can build it in as a layer with the corresponding water vapor diffusion resistance/ permeability or you can account for that in the boundary conditions as a surface sd-value.
What would you say the corresponding water vapor diffusion resistance/ permeability would be for this material?
That depends on the material... we have one in the database in the catalog "generic materials". I t has a sd-value of 3 meter. Best way would be to check that values in the materials datasheet or contact the producer.
Christian,
Thank you. For some reason, I did not check "generic materials", go figure...
