floating point division error
When I run my calculation I get a "floating point division by zero" error. I can run the calculation for 2 years, but when I try to expand it out beyond two years I get the error.
I am using moisture sources.
I'm using climate data for Fairbanks, Alaska, that I've put together using the create climate spreasheet. That seems to be my problem, using a location from the map works just fine. I have 3 years of local weather data that I've exported to a .wac file. Any ideas what sort of errors in my weather data file I should be looking for?
