Hi, I have set up a simple wall construction and run the simulation but now I can't see the orientation options. There is a message 'Dialog is not needed for the currently selected climate conditions.' It's the same for the 3 cases I have in that file now.
Previously (when I could see the orientation dialogue) the wall showed a build up of moisture over the simulation period but now it decreases. Is it me or WUFI at fault?
Thanks for any advice.
Orientation dialogue missing
Re: Orientation dialogue missing
You have set some indoor climate model to your exterior surface and I presume this happened on accident.
In this case that dialog is not needed as only Temp and RH will applied to the exterior surface, no Rain nor Solar
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
Thanks Manfred, I get that dialogue intermitently. When I first open the file that is what I see, then after checking the location (pre installed with WUFI) which was already selected the orientation dialogue works.
