Orientation dialogue missing
archisail
Post by archisail »
Hi, I have set up a simple wall construction and run the simulation but now I can't see the orientation options. There is a message 'Dialog is not needed for the currently selected climate conditions.' It's the same for the 3 cases I have in that file now.
Previously (when I could see the orientation dialogue) the wall showed a build up of moisture over the simulation period but now it decreases. Is it me or WUFI at fault?
Thanks for any advice.
Re: Orientation dialogue missing
You have set some indoor climate model to your exterior surface and I presume this happened on accident.
In this case that dialog is not needed as only Temp and RH will applied to the exterior surface, no Rain nor Solar
archisail
Post by archisail »
Thanks Manfred, I get that dialogue intermitently. When I first open the file that is what I see, then after checking the location (pre installed with WUFI) which was already selected the orientation dialogue works.
