Unexpected water content and temperature in WUFI 2D
WEI LI
Post by WEI LI »
Hi WUFI team,
Please help, I am desperate. Below is the geometry representing a ventilated roof. I have metal decks on both sides of the roof. For the cavity (in light blue), a 250 ACH air change source was applied. The pink part is the PIR board and liquid distribution coefficients were applied to it.
I ran a one-year simulation. The thing is, every variable in every place is unbelievably repeating in a short period of time. Please see the pics below.
The temperature of the outermost metal deck:
temperature of outermost.png (144.3 KiB) Viewed 56294 times
Water content of the PIR board:
At least I would expect that the temperature would vary with the season, but not.
I do not think the settings are the problem cause they are almost all by default, except for the explicit radiation is turned on.
Could anybody please help me? thank you!
WEI LI
Re: Unexpected water content and temperature in WUFI 2D
Post by WEI LI »
I highly suspect it was a numerical issue.
Any clues? Thanks!!
Hi WEI LI,
this may be a bug causing a wrong time step size. Please see here for a solution: Wrong timestep in climate file.
