I know WUFI can be run and outputs can be saved using batch commands, but is it possible to also edit the input file through command line to adjust parameters?
I want to use GenOpt to adjust my initial conditions and infiltration rates, in an attempt to calibrate the model with experimental data.
Optimizing Batch Simulations
Re: Optimizing Batch Simulations
for WUFI Pro it is not possible to change the input data externally.
