Indoor climate how to vary by month?
Imogen
Post by Imogen »
One of the many things that concerned me on the WUFI online course was regarding interior climate.
In my location in Ireland, the interior climate is typically much higher RH in summer.
I know there is a user defined option for this and I understand the "constant" and "sine curve" options.
But I don't get how to make RH for May to Sep average of 87 while Oct to Apr (heating is on) is 73 ?
These figures have been measured previously.
Thanks for any help you can give.
Also, is there any article about creating WAC files anywhere? I can get hourly temp, RH etc from our local weather station, but it seems quite a complex process using the Excel files (like everything WUFI!)?
Imogen
Re: Indoor climate how to vary by month?
Hi Imogen,
most of the user-defined settings are thought to be used to derive an indoor climate based on the outdoor climate. Therefore there is no possibility to enter an course of RH at the moment.
With WUFI there comes an excel file "CreateClimateFile.xlsm" (usually here: C:\Program Files (x86)\WUFI\Tools), which allows to create your own climate file.
For interior climate T and RH are sufficient, while for exterior climates also long and short wave radiation as well as wind and rain (if needed for your calculation) have to be contained.
See here for more information:
https://wufi.de/en/service/downloads/cr ... her-files/
and
https://wufi.de/en/service/downloads/cr ... -for-wufi/
Imogen
Post by Imogen »
Unfortunately the WUFI Windows obsession strikes again!
I have five years of hourly temp and RH data, this is easily downloadable for Ireland, and I don't understand why Joseph complains it is not available.
But I cannot use it because your CreateClimateFile.xlsm uses features of Excel which will only work in a Windows environment on a PC and not online, or on the Mac version of Excel.
It really is a most frustrating experience trying to use this software "in real life".
But thank you for trying to help me.
Imogen
Post by Imogen »
I also have another question. Solar radiation figures are available for our weather station but these are daily (J/cm2) or monthly (hours/month) whereas the outdoor climate file example is per hour in W/m2 ?
Is there any information about how this could be converted for use in your WAC creation tool (since day length varies throughout the year)?
The cost to buy data from Meteonorm is very high - €125 for a single weather station - and it's unclear whether this just "slots in" to WUFI or if further action is needed to create a useful weather file.
Hi Imogen,
there are for sure models to convert daily/monthly data to hourly data for the radiation, as Meteonorm is doing the same, but I have to ask a colleague about that. The Meteonorm files can be exported in wac-format for WUFI and then they directly can be used.
Maybe meanwhile try the climate from this free source:
viewtopic.php?t=1246
You can export as WUFI wac here as well.
These data are more like measured data, so no reference data. But you can export a few years for WUFI and use a longer period for your calculations, so they cover also critical periods.
