My question is how can I find Asphalt Shingle Material and Self-Adhering Membrane in WUFI or alternative material in WUFI?
Re: Asphalt Shingle Material and Self-Adhering Membrane in WUFI or alternative material in WUFI
Hello Alina,
there is a material called "Asphalt Shingle System" in the Northamerican Datasource.
You can find them with the database search function (WUFI Pro 6.x). Just enter asphalt.
For the membrane search one with the same sd-value or permeability as your one, that will do it.
Hello WUFI Team:
Thank you for your reply!
When I search "asphalt" in WUFI Plus database, there is no "asphalt system", I only can find "asphalt impregnated paper".
The version of WUFI Plus I am using is V.2.5.4.0.
Thank you!
Thank you!
Hello Alina,
the material is included in WUFI Plus 3.x.
Hello WUFI Team:
I am applying the student version of WUFI Plus. Which is still wufi plus 2.xxx, how can I get WUFI Plus 3xx?
Thank you very much!
Hello Alina,
we offer free versions limited to 6-months for your student thesis etc. (non-commercial only).
Please sign/log in to our online shop:
http://wufi.de/en/webshop/
In the menu "Students licenses" you can apply for the needed version of WUFI®. All further steps are described there as well.
Thank you very much for your reply!
The "Asphalt Shingle System" has a perm-in rating of 0.0472, meaning that it would have a perm rating of 0.3. This seems low--don't most asphalt shingles have a perm rating of around 0.9? (http://www.owenscorning.com/NetworkShar ... r-2011.pdf)
