How to model a moisture sink
David Lam
Post by David Lam »
Hi all
I had a good search in the forum and couldn't find an answer to what I thought would be simple (easy and complex right?!).
I want to model a cavity drain to see the impact that a moisture sink has.
Reading around it looks like I need to enter a Moisture Source with a negative value. However this does not seem possible.
I was expecting to be able to enter in the box in the screenshot below but this doesn't work. Can you help please?
Screenshot 2021-05-18 194753.jpg (59.04 KiB) Viewed 84720 times
Re: How to model a moisture sink
Hi David,
the monthly moisture loads are meant to be a challenge for the drying potential of the building component and therefore accept only positive source strengths.
To define a moisture source with negative source strength, please use the option "Transient from File". The help file explains the format of a user-provided source strength file.
David Lam
Post by David Lam »
Wonderful.
Thank you.
