I've just done the minor update to v7.2.6 and then most of my files don't load. See screenshot for error message. Seems there's some internal validation of file data - I suspect it's related to some material files that are used that have been sent from manufacturers that some internal check doesn't like. Older files that I remember didn't use those materials are still opening.
I've contacted support, but thought I should post on here as well in case someone else has the same issue!
Error loading files after minor update to v7.2.6
- Update issue.png (36.45 KiB) Viewed 20907 times
