Profiles in the cross-section
Raymond
Post by Raymond »
In Help/Backgroud we see profiles of water content in the cross-section of wall with abscissa values.
Is it possible to make that kind of graph with WUFI 2D ?
The only way we find to do that is to make a screen shot of wufi motion in pause (paint) but we don't have any value on abscissa to see when we change of component.
Thanking you by advance.
Greetings.
veitner
Re: Profiles in the cross-section
Post by veitner »
Hi Raymond,
to enable the abscissa values right click in the water content view, select sidepanel/numbering/enabled
Veit
Hallo Raymond,
there is at the moment no easy posibility to generate a profile out of the 2d calculation.
But there is a kind of tricky way:
You can extract the data for all grid elements for one time step. Open WufiMotion and go to the time step and value window you need. Then rightclick -> extract -> initial conditions. You will get a data matrix with a mean value for every grid element in a text file.
Out of this file you can try to find the right row or column and plot it. The according distance values (for x or y) you can find in the file called input.dat
Good luck,
