Limiting Isopleths Lines
bek15212
Is there anyway to get the limiting isopleths lines LIM B1 and LIM B II in any of the other monitoring position graphs? I only see them on the interior surface graph. It would be a good to have them on the interior side of the drywall, where there is paper, i.e. food for fungal growth.
Bek
We took out this lines on purpose for the LIMs, because they were determined for the conditions on the inner surface. But if you think you have a material in the inside, which is a good substrate for growth, you can also use the model. At the moment you only can extract the temperature and moisture data and combine it manually with the isopleths. In the program itself it is not possible, but in a view days there will be a new post process module available for Wufi which is able to analyze the growth conditions at every position. Just check our website next week. The post process should be called "Wufi Bio".
Since today there is the new version of Wufi-Bio online. http://www.wufi.de/wufi/downloads_e.html#wufibio
Install it, then calculate your construction, got to the Wufi-Film and you will find a new symbol. Clicking that, you can choose any grid element to do a Wufi-Bio-analysis.
Hope that helps,
Hope that helps,
