Unable to run calculation
Sum1
Post by Sum1 »
I recently installed WUFI ORNL 5.2. After I create an assembly and modify the other parameters as required, the option to run a calculation is grayed out. (All the check marks are green and I have saved the file.) I have even tried the sample files included with no luck, as well as reinstalling the program. Any other suggestions?
Thanks!
Hello Sum1,
could you please provide us with Release number.
You will find it at the download menu named "?" | "About WUFI"
Kind Regards,
Sum1
Post by Sum1 »
Release: 5.2.0.972.DB.24.76
Hello Sum1,
in Wufi ORNL you only can calculate with film. Please use the symbol right to the two hourglass symbols to calculate.
