Hello!
I am a beginner of WUFI 2D 4.3.
I am trying to simulate a steel structure modular house junction.
I modeled as below, and I haven't put in the source yet.
An error occurred in the calculation result, and the result is unknown.
What is the cause of the error?
*.wfd simulation result file was not created.
** Questions
1) What is the cause of the error?
2) Is there a size limit for modeling supported by the WUFI 2D?
3) Is it possible to model a 1mm thick steel structure?
Best Regards,
Ahn
HDF5-DIAG : Error detected in HDF5 (1.8.17) thread 0
eunseop ahn
- b5.jpg (489.41 KiB) Viewed 59303 times
- b1.jpg (152.07 KiB) Viewed 59303 times
- test-3.zip
- (823.78 KiB) Downloaded 1871 times
Re: HDF5-DIAG : Error detected in HDF5 (1.8.17) thread 0
Hi eunseop ahn,
your construction is to big for the grid setting, so the grid can not be fully build. There is a little red error message in your grid window, you should not ignore. Please try to increase the maximum grid elements from 150 to 300.
Further you build a detail with a very high grade of details. You should think about simplifying your construction.
eunseop ahn
Hi, Christian Bludau!
Thank you so much for the very quick answer.
I will try again as you taught me.
This WUFI-forum is really helpful, and thanks again to Christian for kindly responding to all the articles.
Best Regards,
Eunseop Ahn
Best Regards,
Eunseop Ahn
hi eunseop ahn,
how did you define the hygrothemal properties/functions of the steel studs?
thanks in advance
thanks in advance
