When I add a moisture source from a transient txt file I get an error when I click on the OK button (see printscreen).
WUFI version 1D 5.3
regards,
Jonas
Error when adding source from transient txt file
- Error WUFI.PNG (60.96 KiB) Viewed 66976 times
Re: Error when adding source from transient txt file
Hello Jonas,
can you upload the source file?
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
Hello Manfred,
in attachment the source file.
regards,
Jonas
regards,
Jonas
- Vochtbron.zip
- (86.97 KiB) Downloaded 2245 times
Dear Jonas,
both files work for me. What version of WUFI Pro do you use? The latest is WUFI Pro 5.3.4.
Hello Christian,
I have version 5.3.3.1353.
I have also problems with moisture sinks with a monthly negative value. When I try to type the yearly moisture load, the program removes the '-'sign.
regards,
Jonas
regards,
Jonas
Dear Jonas,
can you please update to the latest version of WUFI Pro 5 using the download link you got with your WUFI purchase?
The monthly constant source does not work with negative values. That can only be used as a source, not as sink.
